Could you check to see if the rear of your front door, toward the bottom is predriiled for the early seat belts ? I know my 56 Golden Hawk was, but it might have had belts at one time. I'd like to know for my ebay ad for the early belts.
Question for 56-61 owners
How about a picture of the area with the holes? Also, are you sure the holes were intended for belts, or dowel pin holes for the mold to keep the sheet metal in place during the stamping process.
Often these holes are strategically placed to perform a dual purpose. They keep the part properly positioned for forming and serve a purpose for assembly.
Originally posted by jclary View PostHow about a picture of the area with the holes? Also, are you sure the holes were intended for belts, or dowel pin holes for the mold to keep the sheet metal in place during the stamping process.
Here's where the holes should be for the chrome brackets.JDP Maryland
Thanks for the pic. Does this apply to larks too?
I found a box of belts and mounting hardware in my stash this past week while looking for brake parts. When I get a chance, I'll take a look and see if the mounting hardware is for this mounting configuration.
My original-paint 56 Golden hawk front doors do not have any pre-drilled holes.
BTW, looking at page 8 of the 56 accessories manual (which you can pull up on the 56 Studebaker Golden Hawk web site), it appears that the seat belts for 4-door models were attached to the door post instead of the door. Have no idea if 4-door belts were the same as 2-door.Last edited by black56hawk; 11-07-2010, 01:30 PM.
My '56 Power Hawk has seat belts in it, I'm pretty sure that the door was pre-drilled and tapped for the belts. Next time I get in my shop, I'll snap some photos in detail for you...Current projects: '56 Stude Power Hawk
Future projects: '56 Stude Sky Hawk ; '68 Buick Electra 225 ; '53 International R-110 P/U
Originally posted by jclary View PostThanks for the pic. Does this apply to larks too?
Here's the AC part numbers, and the option code is 80 starting in 1956
SP-50060 FRONT SEAT BELT KIT, GRAY (80)
SP-50061 FRONT SEAT BELT KIT, GREEN (80)
SP-50062 FRONT SEAT BELT KIT, RED (80)
SP-50063 FRONT SEAT BELT KIT, BLUE (80)
SP-50064 FRONT SEAT BELT KIT, BROWN (80)
SP-50065 FRONT SEAT BELT KIT, BLACK (80)JDP Maryland
Originally posted by JDP View PostCould you check to see if the rear of your front door, toward the bottom is predriiled for the early seat belts ? I know my 56 Golden Hawk was, but it might have had belts at one time. I'd like to know for my ebay ad for the early belts.
FWIW Dept.
All 1956 Golden Hawk factory installed Front Seat Belts with a 1955 build date were GRAY in color. It was not until January 1956 build dates did non-GRAY belts appear on Production Orders.
Break-down by color of factory installed Front Seat Belts on 1956 Golden Hawks:
SP-50060 FRONT SEAT BELT KIT, GRAY (80) TOTAL 961
SP-50061 FRONT SEAT BELT KIT, GREEN (80) TOTAL 4
SP-50062 FRONT SEAT BELT KIT, RED (80) TOTAL 5
SP-50063 FRONT SEAT BELT KIT, BLUE (80) TOTAL 1
SP-50064 FRONT SEAT BELT KIT, BROWN (80) TOTAL 6
SP-50065 FRONT SEAT BELT KIT, BLACK (80) TOTAL 7
Approximately 1-in-4 1956 Golden Hawks came with factory installed Front Seat Belts.
Originally posted by dong View PostMy 56 Power Hawk does not have predrilled holes.Current projects: '56 Stude Power Hawk
Originally posted by james.seagle View PostI may be mistaken about the pre-drilled holes, but I remember that my bracket and the screws holding on the bracket are the same color of the body...JDP Maryland
