I am working on a 1963 Avanti and thought I could repair the rust damaged frame but found it was beyond repair. After looking at my options I thought I might have to abandon the project until I found this new frame from a 1985 Avanti. It will need some minor changes to mount the body and engine (still has the Chevy motor mounts) but beats trying to repair a rusty frame.
New Avanti frame
That will make a nice story...one of the first Avanti's with a Stude frame mated to one the last Stude frames for an Avanti. You can do a story board called "The First and the Last"!Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
Just for the heckuvit, there's one on eBay right now:
Proud NON-CASO
Romans 15:13
Deuteronomy 31:6
Proverbs 28:1
Illegitimi non carborundum
Bob,
You will need to swap out or rework the x member, the later ones were shorter and modified for exhaust clearance. If not you will have floor pan clearance issues. Also, good luck getting your front end aligned to specs, seems the Blake employees mis-drilled the lower control arm holes. (Been there done that). I bought three of these frames when we moved the stuff from SB to Youngstown. email me if you want for more frame info.
Jim S.I was STUDEBAKER, when STUDEBAKER wasn't "KOOL".
There were only 96 coupes and four convertibles for 1985. I wonder what caused this one to be parted out with a good frame. It could have been a rollover, but not a real hard hit on any side/end. Maybe someone wanted an Avanti on some other frame, but why start with an Avanti with a good frame? There are plenty of Avantis around with bad frames. Do you know the story on this 1985 Avanti?Gary L.
Originally posted by studegary View PostThere were only 96 coupes and four convertibles for 1985. I wonder what caused this one to be parted out with a good frame. It could have been a rollover, but not a real hard hit on any side/end. Maybe someone wanted an Avanti on some other frame, but why start with an Avanti with a good frame? There are plenty of Avantis around with bad frames. Do you know the story on this 1985 Avanti?
This frame was never used on a production Avanti. It was a leftover from 1985.
Jim S.,
Ckeck to see if you received the PM i sent to you.Bob Langer
Glenshaw,PA
