View Full Version : Champ Steering Column Jacket
GTCruiser
08-31-2010, 02:31 PM
Am about to replace the subject on the '63 8E7. Looks easy enough... Two bolts at base on gear box, one bolt on steering wheel, two bolts under dash and mark/match the wires coming out the side for re-assemply. Any concerns or things I should know. Thanks.
08-31-2010, 03:38 PM
It SHOULD be a straight forward swap, IF the years are close enough, 1960 Champs have completely different Turn Signal Switches, so if you are switching from floor to column or vise-verse, with the same year jacket, you should be fine.
GTCruiser
09-01-2010, 07:37 AM
Replacing a '63 jacket with another '63 jacket. Thanks
