Does anyone know if there should be a fan shroud or have a photo of an original engine compartment? My fan is way too far from the radiator.
1950 Stude pickup question.
How about some better pics of the radiator itself? It may be mounted wrong. On my '55 with the small six, the radiator is mounted on the back side of the support. Yours looks like it is inside or in front of the support. On my V8 powered 55, the bigger radiator is in front of the support.John Clary
FWIW I have a '52 pickup with a big 6 and it has a shroud and due to the extra engine length the radiator is even with the grill side of the rad support. I have also a Transtar parts truck with a Champ engine; no shroud and the front of the radiator is offset by a rad width towards the engine. Hope this helps.
I believe both the Commander 6 and V8 came with a fan shroud. Presumably the same shroud could be used with the Champion 6, as long as the fan was located properly. And as noted, the radiator can be mounted two ways. The parts book would tell you for sure whether your truck should have a shroud. I don't have my book handy or I would look it up for you.Skip Lackie
According to the parts book, a five bladed fan and a shroud were optional for extra cooling. My '49 2R15 has about one inch between the fan blades and the radiator is mounted on the rear side of the support.Rick
Kingman, AZ
Ok. The radiator is mounted flush with the core support. I do see mounting holes where it can be moved to the inside, getting the radiator 3 inches closer to the fan, but the filler neck on the top tank would not clear the support that way. I think the truck originally had a big six but now has the champion. Was the radiator tanks different? Can someone please post a pic of the radiator mounting with the champion engine?
