I can't figure this one out. Maybe someone can give me a clue how to get the cigarette lighter to work in my Lark so that I can run a GPS when we head out for a Studebaker roadtrip to the Boston/Cape area next week.
I started out not having any voltage in the base of the cigarette lighter. I removed it tested the round fuse at the lighter base with an Ohm meter. It had continuity. I screwed the fuse back on the lighter case. I found that there was still no voltage through it. What I found was that the screw base of the lighter inner case was not making contact with the inner copper of the round fuse. I remove a lock washer on the inner case ti make the base screw slightly longer enabling the base screw to make contact with copper in the round fuse. That gave me 12.6 volts through the lighter case.
Great I thought. I popped in a lighter and it didn't work. I went over to my Hawk grabbed the lighter and popped it into the Lark. It didn't work either. Tested both lighters in the Hawk and they both work. Neither work in the Lark.
I'm baffled!
Does anyone have any Ideas to get the lighter to work?
Allen
I'm baffled!
Allen
