Before I shut down the pc tonight I thought I would ask for a bit of welding advice.
I have slowly been working to fix a major rust hole in the lower front corner of my 62 Lark Hardtop's right door. I used patch panels cut from a half scrapped rear door off of a 63 station wagon. The hardtop door was not in the best of shape to start and in some places I had to set my welder to the lowest setting because of the thinness of the metal... there were times when the metal heated up it would melt like newpaper would burn when lit by a lighter. I would eventually get things tacked then welded but I ended up spending a lot of time building up metal that just vanished. I would end with solid welds but the fill wire would glop up because of low heat or I had the feed set wrong.
Any advice on how not to melt away thin steel and piling up fill metal that takes time to grind away. I do not remotely claim to be an expert but a lifelong learner with a work in progress.
thanks,
Jeff T.
thanks,
Jeff T.
