Car quit again yesterday about 15 miles from home. I thought that the the new fuel pump plus the new electric pump would solve my vapor lock problems but not true. Car would run when I primed it, but only until that gasoline is used. I worked my way back, starting by taking the top off the carb and never foiund any gas, even in the line leading up to the inside fender next to the engine. Questioning whether that line on back to the tank had a problem, I borrowed an air tank and forced air through the line into the tank-causing lots of gurgling sounds. I then put it all back together, primed it and it started and ran fine till the car got warmed up, then it started acting like it was out of gas again. I pumped and pumped and finally got it going again and finally took country roads home on which I could go slow and made it home. When I got ready to pull it into the shop, it wouldn't start again. I think that while sitting, it vapor locked again due to the gas line heating up do to its proximity to the exhaust pipe passing near the fuel line. This morning I got under the car and looked and found what I suspected, the fuel line which I rerouted several months ago while redoing the car, long before I had the exhaust system installed, is about 2 inches above the exhaust pipe that leads to the muffler. I read that gasoline in some cases can boil at a temperature of 100 degrees. I feel sure that the reason the car will not run after it is hot is that I have a very serious vapor lock in the line leading to the electric pump. Apparently, the electric fuel pump cannot "pull" the vapor through the line. My next plan is to reinstall the electric pump near the fuel tank so it can "push," as others told me I should have done in the first place and I plan to reroute the fuel line away from the exhaust pipe and will most likely install a shield for the line in that area and another shield between the engine and the regular fuel pump.
Hoping others can avoid problems by reading about mine.
