My 1950 2R10 has the optional HD 4 speed T9 transmission, with spur gearing and no synchromesh at all. Double clutching is no problem, but lining the shift lever up with the shift pattern the transmission wants is a bear. The result is a really nasty gear clash that happens a lot more often than I would like. I am living on borrowed time before I cream the transmission. I think I want a T98 transmission that is both 4 speed and synchromesh (2nd, 3rd, and 4th). My questions are:
1) What model years and model numbers had this transmission either as standard or as HD option? I understand T98s were supplied in enough models so that they should be reasonably available.
2) Is a T98 a true bolt-in application - same bell housing, clutch, propeller shaft flange etc? My truck has a Champion engine, and many 4 speeds were mated to Commander engines.
3) Are all the bits and pieces interchangeable, such as driveshaft parking brake, floorboard cover, driveshaft flanges etc. Or do I need to find a complete donor truck? There are lots of big grain trucks sitting in fields in Montana, but I don't want to have to go that far (I live in the Seattle area).
4) What do I need to ask to have a reasonable change of getting a T98 that is in good shape and that likely does not need overhaul?
5) What is the going price for a decent T98?
Any answers or advice would be much appreciated. Many thanks, Phil B.
