OK...to sum up my issues: Throw-out bearing and clutch disc are both frozen to the input collar/shaft in my 63' V8.
I now have the drive train sitting on the floor on stands. I can see through the inspection hole: the T-O bearing, the pressure plate and the splined area of the disc. I think I can get a flame through that round hole and heat up the disc splines. Is there any reason not to try this approach ?? It certainly sounds better than cutting a hole through the b-hsg or attempting to access the P-plate screws through the starter opening.
I plan to separate the b-hsg from the block with spacers in 4-5 perimeter locations to put a good, even stress on the block/bellhousing....Shouldn't it simply "POP" like a rear hub w/ correct puller ????
