I have a 259 w/Edlebrock 500 cfm carb, port-matched heads with R3 valves, Harbit R2+ cam, T-bow electronic distributer, and TH350 transmission in my M truck. Mid 70s Corvette master cylinder and booster. When the truck is warmed up and stopped at a light or stop sign, it will suddenly lose vacuum and rev up to around 1400 RPM. Take it out of gear and it slows back down but is still low on vacuum. Otherwise holds around 17 inches. Its intermittent and driving me crazy. Truck went about 17,000 miles with no problems then started this. So far, I have replaced the booster (twice), check valves, modulator, all rubber lines, and installed a large vacuum canister. It does it with the PCV valve taken out of the system. The system will hold 21 inches of vacuum overnight.
Any ideas?
Any ideas?
