In the few miles I have driven my newly-acquired '64 Daytona convert I have noticed what sounded like an annoying exhaust rattle. When I re-installed my exhaust manifolds last week I looked at the exhaust and could see that it was not bumping anything. Today I decided to try to track the down the rattle. Ron Butts had suggested that bad sway bar bushings can make a racket so I wanted to check them up close and personal. I jacked up the car, installed the jack stands and crawled under. Sway bar bushings looked good- very tight. The lower A-arm bolts were tight (see near calamity #1 below). All bushings looked good. It sort of sounded like a loose shock so I looked at the bottom bolts. They were tight so I looked at the top. They were tight. The upper inner A-arm bushings looked good, but something looked strange. I took hold of one of the cap screws on the end of the pin and it wasn't even finger tight. I checked the other side- same thing. Both front screws I must have tightened 10 - 15 turns. The left rear one was properly tight, but the right rear one was also loose. I tried to torque them to the prescribed 50 - 55 foot-pounds, but my two-year old Craftsman torque wrench has decided that it doesn't want to ratchet any more. So, I tightened them as best I could with either a 9/16" socket and ratchet or a ratcheting end wrench until I can collect a new wrench at Sears.
OK- near calmity #1. About 18 months ago I was carrying a bridesmaid and a groomsman in my '64 Avanti as part of a Studebaker-based run from the church to the wedding reception. The trip was maybe 15 miles on a curving, mountainous road. After I dropped them I started back, first over the same road then on I-70 where I running about 75 for 20 or so miles. After that, another 20 miles of two-lane road. As I turned off the highway on to the road that goes to my house (four miles to go), I hear a loud clunk and the steering got wierd. I crept along at 10 - 15 mph the rest of the way home. This was approaching 11pm. I took my trusty Maglite and looked under the car. The left lower A-arm was hanging down about two inches below the frame. All the nuts and washers were missing from the bolts that held the inner pin to the frame.
I guess my message is- check ALL your suspension parts. Don't take a "nice" car for grtanted.
[img=right]http://www.frontiernet.net/~thejohnsons/64%20Daytona%20Convertible/Copy%20of%20DaytonaConvert7-20-06.JPG[/img=right]
Paul Johnson
Museum R-4 engine
Paul Johnson
Museum R-4 engine
