I have a chance to buy what appears to be a 57 or 58 Golden Hawk. Something appears a bit odd, though. Although it is a Hardtop (no pillar) has the v-8 engine with the metal housing on top of the carb for the air inlet and has all golden hawk trim, it doesn't have the boost gauge or the tachometer on the dash. It is also missing the supercharger. I realize that it isn't unusual for golden hawks to be missing the supercharger, but didn't they all come with a boost gauge and a tach?
curious golden hawk
Yes, they did have those two gages. What does the body tag say? That's the tag near the right hand hood hinge. If the top line ends with a K7, it (that body tub anyway) started life as a Golden Hawk.[:I]
1963 Daytona project FSNo deceptive flags to prove I'm patriotic - no biblical BS to impress - just ME and Studebakers - as it should be.
It's also not unusual for someone to have altered the hood and trim to make it look like a Golden Hawk. To verify the model you'll need the numbers. Body tag on the cowl under passenger side of hood should say K7.
Brad
33 Rockne 10
51 Commander Starlight
53 Commander Starlight
previously: 63 Cruiser, 62 Regal VI, 60 VI convertible, 50 LandCruiserBrad Johnson,
'56 Sky Hawk in process
I looked at the hawk again last night. The body tub number is 57H-K7. VIN is 6101358.
So it looks like it is a real Golden Hawk. I still wonder why the dash does not have boost or tach. Judging by everything else in the car (carpet, seat upholstery, headliner) everything seems to be as it was when it left the factory, although much the worse for wear and tear.
Body wise the car is in good shape. The only rust is on the two front fenders near the vents, just like every other Studebaker ever made.
The undercarriage is rust free as are the floor boards.
It is missing the supercharger and the air cleaner. Other than that it appears complete.
The seller wants $6,000.00. Any thoughts?
Thanks.
It's possible that someone swapped out the dash for one from a lower trim level Hawk because the original was not in the same shape. The good news is if you cut the hole and add the boost gauge, nobody will ever know the difference.
If it is in good condition, and is only missing the items you mention (i.e. all the supercharger pulleys and brackets are still intact, still has the original fuel pump, etc.) it might be a good deal. I suspect it will take you a while to find a full working tach setup but I can help with the wiring once you find all the pieces (see my web site.) I'd take a good look at the drivetrain and make sure everything is all original, as I would ASSume that you'd want to put it back to stock. If it's an automatic, it should have a water cooled FOM; if a stickshift it should have a T-85 with overdrive, not the normal, smaller T-86. Check the engine number and make sure it makes sense for a '57. I don't know what to look for to make sure that it's a real Golden Hawk engine, but I ASSume it would be the head casting numbers. Maybe someone else can jump in here. It should still have a two piece driveshaft as that change was not made until 1958.
good luck,
That serial (VIN) number is correct for a 1957 Golden Hawk. The engine number should start with a PS_____. Look at top left (driver's side) front of engine block, next to the oil fill pipe.
Is there a clock or a blank-off plate on the dash just to right of center where the tach should be? Is there a hole or anything at top center of dash for the vacuum/pressure gauge? And is there two sets of distributor cap hold-down clips riding piggy back to accomodate the tach sender?
Dwain G.Restorations by Skip Towne
One thing in your favor if you do decide to buy it, all the dashboards have the holes already opened behind the dash face. Since its going to need work, you can trace the holes from behind, then when you remove the instruments, which hold the panel in place ou can cut out the proper sized holes.
When you say the flloors look good, what about the sub floor boxes, and do the doors sag, or droop when open, and can you close them with out force?
Proud owner of the Hawk from Hell...... aka as a tow truck queen
Supercharger and carb box can be had for $500. but I don't have the bracket and pulley.
Brad
33 Rockne 10
Gary
1946 M-16 fire truck
1948 M-16 grain truck
1949 2R16A grain truck
1949 2R17A fire truck
1955 E-38 grain truck
1957 3E-40 flatbed
1961 6E-28 grain truck
1962 7E-13D 4x4 rack truck
1962 7E-7 Champ pickup
1962 GT Hawk 4 speed
1964 Avanti R2 4 speed
1964 Cruiser
And various other "treasures"
Hiding and preserving Studebakers in Richmond & Louisa, Va.
