As soon as Dick put the link to Lucas Tire on the forum I called and ordered the Port-a-wall white walls. I found out a couple of things:
# 1 I'm not as tough as I once was.
# 2 There is a new thing called safty rims that wasn't around the last time I used these.
# 3 The radial tires don't work out as well as they leave a wrinkle in the bottom.
# 4 I should have gone with 2 or 2 1/2 inch white walls for the year of car.
I used a rather heavy duty "bead breaker"
Here Is a finished picture. You can see the small wrinkle at the bottom of the tire.
1961 Lark
1961 Lark
