Can someone suggest the first ajustment I should make on the doors of a 56B coupe. The doors are about a 1/4 in. out at the back bottom, like the door is not closed. The front edge of door is flush and the top of doors are closed good. Doors open and close easily. Does not look good like this.[xx(]
Doors on a 56B
I shudder to tell you what they would do at the factory.
Situate a 2x4 between the top rear corner of the door and the body and gently push the bottom rear until the door conforms. They would probably push violently, but they knew what they were doing.Brad Johnson,
'56 Sky Hawk in process
IIRC, that coupe had new rear quarters put on it when it was painted. I wonder if those can be/should be adjusted.
Bellingham, WA
This 2X4 technique sounds babaric but it works. I twisted the tailgate on my PU, thought it was ruined. Went to the body shop and asked if there was a way to save it. The guy grabed a chunk of wood, put it between the gate and body on one side, pushed hard on the other. Worked great, no charge!
Don Wilson
53 Commander Hardtop
64 Champ 1/2 ton
WA stateDon Wilson, Centralia, WA
40 Champion 4 door*
50 Champion 2 door*
53 Commander K Auto*
53 Commander K overdrive*
55 President Speedster
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly owned
1959 DeLuxe pickup (restomod)Gary L.
