View Full Version : Stock electronic ignition vs. aftermarket
Scott
03-13-2007, 11:31 AM
I've been wondering for a while about the electronic "transistorized" ignition found on later Studebakers. My 1966 Cruiser has it, but it was disconnected in the 1970s because some mechanic was servicing the ignition system on the car and couldn't figure it out. So I have no first hand experience with the stock system.
My question is: Is anyone using the stock transistorized system on their car? How does it compare to the regular points and condenser setup of the same vintage? How does it compare to new electronic systems put into an older Studebaker.
I have heard that the stock system wasn't really that good, but I tend to think it must have been pretty decent when new, or Studebaker wouldn't have put it in their cars.
I don't want a debate about different new systems and how great they are. I want to know about the original setup and good IT was or is.
64V-K7
03-13-2007, 02:45 PM
The early transistor ignitions still used the points as a low voltage switch to trigger the solid state section. I'm not sure what tolerance was needed to assure the correct function of the electronics, but with the poor track record of Prestolite distributors, it alone may have been the cause of your unit not functioning. That said, underhood heat still works against transistors, modern or vintage. Keep the look and install a Pertronix.
Bob Johnstone
http://www.studebaker-info.org/7168422/sig2.jpg
64V-K7
Bob Johnstone
Skip Lackie
03-13-2007, 02:46 PM
I don't think any of those early systems were very reliable. I cannot speak for the Studebaker system, but I had a 67 Corvette with the early Delco electronic ignition system. GM replaced four of them under warranty before the warranty ran out. When they die, the car stops -- wherever you are at that moment. That got kinda old after a while, and I switched to a Mallory distributor with old-style points.
Skip Lackie
Washington DC
Skip Lackie
Skip Lackie
Washington DC
Scott
03-13-2007, 03:07 PM
Wow, Skip. That's bad. I hazily remember now all the gripes people used to have about electronics in cars, not to mention computers. I still think simpler is usually better, but I have to admit cars have been getting much reliable over the last several years, in general.
I hope Studebaker didn't have quite that bad a time with the units they installed.
Scott
Swifster
03-13-2007, 09:19 PM
Just a little more filler about older units in general. A buddy had a '74 Road Runner and I had a '78 Country Squire. Both units would go out without any warning. I kept two DuraSpark II modules in the glove box just in case. I didn't realize until after I sold the car that Ford extended the warranty to 100K because of all the problems. I must have gone thru 4 or 5.
Tom - Valrico, FL
1964 Studebaker Daytona
http://i74.photobucket.com/albums/i280/Swifster/1965_Studebaker_Commander_front198x.jpg
Swifster
Tom - Valrico, FL
showbizkid
03-13-2007, 10:49 PM
That Duraspark system was the worst. I had that setup on my '87 Wagoneer. Every so often the truck would just... shut off. I'd throw it in neutral and fire it back up again, but it was a pain. Sometimes I'd have to get out and whack the box a couple of times to get it sparking again. I replaced the control module a couple of times (Echlin parts, Hecho en Mexico) and she'd run great for a while and then crap out some more. Never did shake the gremlins off.
Clark in San Diego
'63 F2/Lark Standard
showbizkid
Clark in San Diego
mapman
03-14-2007, 01:09 AM
my '64 Cruiser has the studebaker electronic module still under the hood although it has been converted back to points. The car belonged to the dealer till '94 when I bought it so I would guess that it didn't work out well. I've never tried hooking it back up, it is just kind of interesting to see it there.
Rob
mapman
Rob
hank63
03-14-2007, 02:56 AM
in my experience, the "electronic" breaker points are worth having. I have had several different makes of cars with 'em and have no complaints. The rest of the electronics seem to have a built-in self-destruct mode. The Chrysler Lean-Burn system would have to be among the worst under-performing systems. Didn't last long, either.
/H
hank63
/H
53k
03-14-2007, 08:17 AM
One dealer I bought out had five or six of these units NOS in the sealed boxes. When I was selling them at York a man told me that the reason most of them failed was because of poor grounding. Somewhere I have a Service Bulletin that dealt with properly repairing and installing the units. The man who told me about the problem said they were good reliable units. They were standard equipment on R-3/R-4 Avantis (yes, I know there were no R-4 Avantis).
Museum R-4 engine
53k
Museum R-4 engine
53k
03-14-2007, 08:22 AM
Re modern systems in a Studebaker, I have had both the Pertronix and Dave T's converted MoPar systems. I much prefer the MoPar. It has the disadvantage of having a control module box that you have to hide away, but it seems to provide a stronger spark and, from what I have heard, it is more reliable. My '64 Daytona convertible has an electronic system that doesn't appear to be Pertronix. It gives me easy starts, but it is a little annoying to have to wait a few seconds after turning on the ignition before you crank it (if you don't, it won't start).
Museum R-4 engine
53k
Museum R-4 engine
