Hawk front top plastic fins
  • Hawk front top plastic fins
    Did the plastic fins on top of the fender on Hawks light up?
    On the 1963s and 1964s they did. The 1962 hawks did not, but you could probably install lights if you wanted to.
      What lite them up? Fiber optics or what?
        What lit them was a small bulb and socket. The socket&cable is part# 1353741. It mounts right below the plastic ornament. There was a differnt part# used for export cars. I'd bet maybe it used an amber insert.
          Oddly enough I was just messing with one of these today. In a 63-64 GT Hawk there is another wire that runs to the front of the car that taps into the wire feeding the high/low beam switch, so it is "hot" whenever the headlight switch is up. If you ever have the pleasure of R&Ring one of these lights you will see that they seem to be designed for the sole purpose of trapping water and dirt and rusting to nothingness. I would highly recommend if you have these lights and they work disassembling them, running a thin bead of silicone along the bottom edge of the chrome piece, and along the surface of the plastic "fin" where it screws to the chrome piece, and finally adding a grommet to where the wire goes through the steel plate (if you've had it apart, this will make sense.) Finally, some silicone/dielectric grease in the bulb socket would be an excellent idea as well. Or, you could just not drive in rain.
          Keep in mind that to remove these "fin" lights you will need to slide the fender top stainless trim back 1/2" or so. If you are careful you can do this without barfing up the paint.
          62 Daytona hardtop
