I finally got my 51 Champion up in the air for a good look and lube and found the only major problem to be the rear engine crossmember. It appears the windshiend leaks on the driver side, and over time the floorpan rusted through from the inside out, and then on to the crossmember outboard the frame rail. Does anyone know where I may find a replacement crossmember? The parts book indicates part # 529069?
