View Full Version : Serial Number
curt
08-04-2005, 06:48 PM
Is the serial number on the fire wall under the hood? Mine number located there is 6H-Y
10183 What does this say?
curt
08-04-2005, 06:57 PM
That # should be 6H-Y6 10183
08-04-2005, 07:02 PM
That's not the serial #. That's the body # - 6H says it is a 55 President - Y says it's a long-wheelbase 4dr (but there should also be a digit after that "Y" to denote trim level - a 3 or 4 or 5 or 6 ... a "Y6" would be a President State 4dr sedan)
The other number is simply that particular body's sequence in the line of 6H-Y* bodies that were welded up for future use.
The serial # is on the door jamb - on a stainless steel plate that's spot welded to the jamb, between the door's hinges.:D
curt
08-04-2005, 08:47 PM
Thanks Mr. Biggs. It is 6H-Y6. A person new to a brand( Studebaker) needs help.
KevinSheen
08-04-2005, 08:53 PM
Curt, I'm new too so I know what you're going through. I would suggest that you comb through the numerous web-sites for Stude clubs from around the country. There are plenty which can be linked to through this site. They've usually got want-ads for old repair and parts manuals. I have bought a repair manual from a guy in Indiana and a parts manual (both originals,BTW), at about half the price you'll see advertised for reprints from the parts houses. Good luck.
Kevin in the Stoogebaker
1963 Champ
Alex Donghi
08-04-2005, 09:45 PM
I purchased a few months ago a 6h-y6 Duet acording to the Studebaker archives serial 7166704. It was painted 2585 Tilden Any body know what Tilden is? The interior is a light green
10183 What does this say I don't think that is the whole serial number
Dwain G.
08-04-2005, 10:38 PM
The color Tilden Gray is shown here:
http://autocolorlibrary.com/cgi-bin/search/searchpic.pl?1955-studebaker-pg01.jpg
In some years Studebaker used a code word to positively identify each body and transmission combination. This was one way to eliminate mistakes in ordering. A 'Duet' was a President State sedan with automatic transmission.
Most of these cars would have been painted a two-color combination. Is your car one color? Just curious, where are you located?
Dwain G.
curt
08-05-2005, 07:09 AM
The 10183 is stamped on the body tag, on the firewall under the hood, on the same tag with 6H-6Y. My serial number tag is on the door/frame ,as I understand. The serial number is = to todays VIN number, it is the one on my title.
curt
08-05-2005, 07:12 AM
Kevin, thanks for the information about numerous sites, I'ave seen only one or two. What Studebaker has your fancy? I think they are all so unique, each model series is a stand out.
Alex Donghi
08-05-2005, 09:13 AM
Thanks Dwain
The car was painted black and it looks like a step down from an Earl Schieb job too runs and all. Some one also fooled with the interior color spraying the dash steering column etc a lime green. Looks like from the spec sheet black wasn't even an option. The car otherwise is in very good shape no rust to speak of as it sat in someones private colection up in Evansville Indiana for many years. It also seems to be the 1st 12 volt model. Ill post a pic of it if i can figuer out how to do it well i guess i need help on this one seems to be a dead short between the chair and the key board [?]
Transtar60
08-05-2005, 12:07 PM
If its not a 1956 or later car, it was originally 6volt. I hope somebody converted it as opposed to just putting a 12 volt in there to run it till something fries.
Dwain G.
08-05-2005, 01:36 PM
<SNIP>
It was. It's just that those paint chip charts are seldom complete. If you would like to see printed articles on the '55 Presidents, try to purchase these Turning Wheels back issues: 2-94, 3-94, 7-04.
Dwain G.
Alex Donghi
08-05-2005, 04:29 PM
I am by no means an expert in fact rather ignorant on Studes but it seems to be a 12 volt system. This car someone told me was a mid model year change. I still haven't seen a similar one in Turning wheels etc Could that affected the electrical system?? This car has the wraparound windshield
Alex
Sam Roberts
08-05-2005, 05:28 PM
As Transtar60 said, all 1955s were 6 volt systems. The June build Commander coupe I had was 6 volt, and worked quite well the 12 years I owned it.
Alex
Sam Roberts
08-05-2005, 05:46 PM
No "midyear change" for voltage. If your's has a 12volt system, it's because someone converted it to 12volts. Fairly easy to do if you just continue to use the original 6volt starter - which will take 12 volts, no problem and doesn't care about the polarity switch that occurred when they went from 6 to 12.
IF they changed the starter to a 12 volt unit, the flywheel ring gear would have to have been changed or that ring gear and the teeth on the starter bendix would suffer in short order. The reason is, that 6volt - 12volt starter gears have a different number of teeth.
All the other stuff - generator/regulator, bulbs, OD solenoid (If overdrive equipped), WW wipers, heater blower motors - all that can be swapped with 56-7-8 and later 12volt items.
Chicken Hawk
08-05-2005, 09:24 PM
If I remember correctly, both 6 and 12 volt starters have the same number of bendix teeth (9 I think) but the 6 is larger diameter. The 6 volt ring gear has 133 teeth and the 12 has 162. I forget a lot anymore so I could be wrong.
Ted
Alex Donghi
08-19-2005, 08:31 PM
I just finished getting it back to runing. All new hoses fluids rebuilt radiator starter Etc etc. Dwain I missed some of your coments RE paint acording to The Stude archives it was the Tilden it didn't say anything else Ill check again tho. Some one painted it black and its not even a decent job. This car sat in a private collection I was told in Evansville IN for over thirty years could be BS but there is no rust on this car to speak of so it wasn't in weather. I am located in Atlanta if you want to eyeball it. The radio was removed so maybe that had something to do with the voltage sytem change. I found a radio at the Atlanta meet back early summer Anybody know where it could be fixed and to 12 volt or maybe put new guts in it? I'll post a picture if some one will walk me thru this.
Alex
curt
08-19-2005, 09:03 PM
Alex, I had a radio repaired some years ago . I found many radio repair people in Hemmings. I have seen someone selling Studebaker radios and repairs of Studebaker radios via Turning Wheels, e-mail : plandd@verizon.net or phone # 310 398 7431 . See page 59 of Sept Turning Wheels.:)
Alex Donghi
08-20-2005, 08:30 AM
Curt
thanx
Alex
