View Full Version : Isn't it nice when things aren't so bad after all?
tstclr
03-05-2007, 09:13 PM
Since the Lark didn't sell, I decided to get cracking and started doing some floor repairs on the weekend. I'm glad I didn't spend the money on complete pans as it turns out mine aren't NEAR as bad as I had originally thought. The worse spot is where the drivers seat belt mounting bracket is:
http://i31.photobucket.com/albums/c351/tstclr/floorresto3.jpg
The floor around the holes looked punky but after spending an hour cutting out a larger than needed area and wearing out a couple of cutting wheels, I found that the steel is actually quite solid! Here's the piece removed:
http://i31.photobucket.com/albums/c351/tstclr/floorresto4.jpg
I removed the THICK layer of undercoat from the piece I cut out and found excellent green paint in all the areas about 3" away from the seat belt bracket. The bracket must have trapped moisture. Being the curious guy I am , I hammered away an area of thick undercoating nearby to find this:
http://i31.photobucket.com/albums/c351/tstclr/63Lark/origfloors.jpg
More shiny green paint! Looks like the majority of undercoating was dealer applied and not by a previous owner trying to hide a bunch of sins.It's a huge relief to find the underneath of my car is much better than I expected. :)
I'll post more photos as I progress.
Todd
63 Lark 2dr Sedan
http://i31.photobucket.com/albums/c351/tstclr/larkavitar.jpg
Michidan
03-06-2007, 07:17 AM
The experience I had with my 52 was that anywhere this thick factory undercoat had stuck fast, the floors were perfect. The stuff looks like heck and it's probably full of asbestos and who knows what other nasty stuff. But it sure did the job.
I imagine it's main use was sound deadener. If only they had spread it everywhere along the tourque boxes and backs of rocker panels and more. Would have saved me a year of rust repair.
Dan
52 hardtop
Michidan
Dan
52 hardtop
N8N
03-06-2007, 10:22 AM
I'd personally just rather see paint... my '55 has lots of the factory undercoat on it and it is very dried out and is peeling off in sheets. At some point I will have to put it up on jackstands and spend a weekend with a plastic scraper getting rid of it all. I'm sure if it were driven in a damp/salty climate it would have rusted away to nothing by now
N8N
fh929
03-06-2007, 09:17 PM
I live in Northern N.Y. I am sure my 37 was driven in winter here .every place the undercoating was { it was removed during resto},there was no rust. We have VERY salty roads.
fh929
tstclr
03-21-2007, 04:58 PM
Well, I got the floors pretty much finished up. It's not anything concourse, but I saved quite a few bucks (I have maybe 50 bucks invested) which is money I can invest in what you can see.. Here's some photos:
First I butt welded in three patches-the largest being where the drivers seat belt mounting bolt is. After grinding the welds, I gave everything a coat of "Zero Rust":
http://i31.photobucket.com/albums/c351/tstclr/floorRepair1.jpg
Next, I copied the previous owner by applying a light coat of filler to smooth things out:
http://i31.photobucket.com/albums/c351/tstclr/floorRepair3.jpg
After sanding that smooth, I coated the area with tremclad as I exposed some metal where there was high spots. I went a little overboard here -especially where the drivers feet will be:
http://i31.photobucket.com/albums/c351/tstclr/floorRepair5.jpg
Finally, when that dried, I coated the works with liquid bedliner to match what was done on the floors in the past:
http://i31.photobucket.com/albums/c351/tstclr/floorRepair7.jpg
They didn't turn out too bad:
http://i31.photobucket.com/albums/c351/tstclr/floorRepair8.jpg
Again, this isn't how I'd do things on an original R2 Lark, but for my little former 6 cylinder Lark, they will do fine for now. They are strong and all metal. There's nothing stopping me from cutting them out and putting repro pans (or southern pans) down the road.
Now all I have to do is remove the glass, dash, do wiring, clean up the engine compartment, rebuild the suspension, tear down the differential, clean up the engine, do the 4 speed conversion, upholster the seats, do the brakes.............
Todd
63 Lark 2dr Sedan
tstclr
Todd
63 Lark 2dr Sedan
showbizkid
03-21-2007, 05:12 PM
Doesn't it feel great to get something finished? :)
Clark in San Diego
'63 F2/Lark Standard
showbizkid
Clark in San Diego
