I pulled the engine in the 62 Hawk with the idea of sealing oil and water passages,as well as cleaning out the water passages. After pulling the engine, I found the timing gear cover is cracked (actually there's a hole in it) and the heat riser (or spacer between the exhaust manifold outlet and the exhaust inlet) is cracked in half. Does anyone have either or both of these parts and could I get them? Thanks in advance.
Laisez le bon temps roulez avec un Studebaker
