I am running Autolite 85 plugs in the Hawk (289 full flow engine), since July of last year. They have been working fine, but because I need to replace the valve seals (got the parts, just need the time now[:I]) the plugs are now fouled. Also since I replaced the plugs I have installed a Pertronix Ignition and Coil.
The question is: Do I need to regap the plugs to a wider gap, and if so what should they be gapped to now that I have the electronic ignition and alcohol containing gasoline!![)] Or should I stay with the repair manual spark plug gap recommendation?
Laisez le bon temps roulez avec un Studebaker
