The car is happily back on the road after some major projects and a number of upgrades. Original engine was rebuilt with a NOS 289 crank and Fairborn pistons, needed 0.060 overbore. Also used Phil's R Plus cam and heavier valve springs. The howling, dripping original rear end was replaced by a NOS Twin Traction assembly that I had purchased from Newman & Altman in the early 80's. The 3.31 ratio is a great match for the upgraded engine and Detroit Gear automatic. With the brackets for traction bars already welded to the axle housing at the factory, I couldn't resist adding the radius rods and front brackets (from Dave Thiebault). The missing front fog lamps were replaced and reconnected to the original harness without mishap. A NOS third horn was also reinstalled. I even replaced the shapeless aftermarket black rug with a beautifully fitting carpet set in original Rangoon Red from Rene Harger. It all works! At many steps along the way, the contributors to the forum were a great help. Thank you all.
Gil Zimmerman
Riverside, CA
1955 Speedster
1956 Golden Hawk
1958 Packard Hawk
1958 President
Gil Zimmerman
Riverside, CA
1955 Speedster
1956 Golden Hawk
1958 Packard Hawk
1958 President
