Made another compression test, using a prof tester. All cylinders 155 except # 2 at 180. Squirted 4 shots of oil into each cylinder, that resulted in 5 cylinders unchanged and 3 cylinders increased 5 - 10.
What I don't know is how much should compression increase if rings were bad? Is 5 - 10 just normal usage for an engine with 85.000 miles? Is 155 normal with thick head gaskets? Why then do I have 180 in one cyl?
Lots of questions!
Lots of questions!
