I hook mine up to the ignition positive with chassis ground.
Edelbrock 1406 question for the techs
Well I have an automatic 700R4 OD. Am not sure I have an electrical wire going to my tranny? is this mandatory to have on all tranny? I do know i have the tranny kickdown cable. Am learning new things about this car as I work on it, when I bought it had the 350 and the tranny already installed.1957 Studebaker President Sedan 57H-W6 2606
Did you get an adapter for the transmission TV cable to the carb hook-up? Very important http://www.transmissioncenter.net/subject.htm scroll to the bottom for a picture. I aree that you shouldn't use the 12 volt wire to tne coil. I've used an ignition powered wire to the wipers frequently with no problems.
There should be a wire going to the trans to power the torque converter lock up solenoid but if it's installed correctly it wouldn't be live when your foot is on the brake. If there is no wire then you will not have lock up and you may cause damage to the trans.
ErnieR
1988 "Beater" Avanti---R5388 @ Macungie 2006
I ran mine through a oil pressure switch so it doesn't work until the engine starts. I seem to recall some
factory hook-ups connected to the S terminal on the alternator(not all alt. are equipped with this terminal) which would accomplishe the same thing.
