View Full Version : Need Hawk Drive shaft yoke
RICKJ
03-02-2010, 03:10 PM
I hope this is the proper place to ask this , if not let me know and I will withdraw it
I am installing a 700R4 transmission in my 56 Skyhawk with the Stude 289
I do not want to destroy my original 2-piece drive shaft . I want to install a new one piece drive shaft. I have the chevy yoke for the front but need the rear yoke for the shaft to fit the stude rearend
If anyone has a old drive shaft and could cut off the rear yoke
I would very much appreciate it. I will work out any cost you need to do this
Please contact me @ RJ1313@yahoo.com
Rick
rusty nut garage
03-02-2010, 03:28 PM
check with your local driveshaft shop they can get you the yoke
Rick
http://i401.photobucket.com/albums/pp100/rustynutgarage/100_0133-1.jpg
53 2R6 289 5SpdOD (driver)
57 SH (project)
60 Lark VIII 2dr sd (driver)
N8N
03-02-2010, 03:52 PM
yes, just ask for one for a Spicer 1310 U-joint
Starlight
03-02-2010, 05:05 PM
Tell your local drive shaft shop what you are doing and they can supply you with the correct u joint to make it work....Done this lots of times.......Keep on Studebakering
wcarroll@outrageous.net
03-02-2010, 07:29 PM
If you can't fid a local "driveline/drive shaft" shop, contact your local 4-wheel drive performance/accessory shop and they'll point you in the right direction.
http://community.webshots.com/user/s2dbaker?vhost=community
