Best engine stand idea!
quote:Originally posted by bams50
Check this out- what an excellent idea!
Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
Jerry Forrester
Forrester's Chrome
An absolutely great idea, if one has access to an old pallet jack for cheap money. However, around here, operating pallet jacks usually go for $250. I'm immediately starting to look for one with blown hydraulics, as the lift wouldn't be necessary for this application.
thnx, jack vines
PackardV8PackardV8
Like you I have already looked around a little for one. One change I would do is source some solid wheels to replace the front rollers to make for easier rolling.
If I find a source for CASO pallet jacks I'll let everybody know
Parish, central NY 13131
quote:If I find a source for CASO pallet jacks I'll let everybody know
Part two - If an operating pallet jack is found, I can see how the engine stand can be designed and constructed to fit over the pallet jack for being moved, but stand on its own feet when the pallet jack is needed for its primary use. Not necessary to weld the stand to the jack
thnx,jack vines
PackardV8PackardV8
I used an old style metal grocery store cart. Just whacked off the top basket. With very little modification was able to set a 259 engine and tranny combo on it. You know, "Let's go Krogering" I went to the rear out side of the store and there were plenty of beat up buggys there. Asked the manager and he said take a couple. Sure does roll and maneuver nice on a concrete floor. Turns on a dime. Yippi-ya-o-kay-a jimmijim
Stude Junkie+++++++Do it right the f$$$$ Time. Never mind. Just do it right. When youre done your done. You'll know it.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Yeah, the "source" comment was tongue-in-cheek. Location is key of course.
Another thing I'd do is build a modular mount that would unbolt and accept a different fixture for different engines. A step better is what you said IF your jack is operable.
Maybe we can brainstorm an excellent idea into an even BETTER design!
I've never found a shopping cart yet that would go in a straight line.
Doug
Venice, Florida
1950 Champion
9G F1
Doug
Venice, Florida
1950 Champion
9G F1
