I finally got around to treating my hog troughs today. Instead of painting them I used a product called Corrosion Block here is the link:
After pulling up the door kick plate and rolling back the carpet I drilled some 1/4" holes staggered along the door frame inside the screw holes for the door trim. I sprayed one full can, 12 oz inside each side thru the holes and also used the rear bottom drain hole at the bottom rear of the trough. The corrosion block really spreads and coats and I sprayed it from every angle thru the holes including the door hold down screw holes.
I plan to do this at least twice a year. My troughs are very solid and this treatment should keep them that way for a long time. The car is always garaged and never out in the weather or driven in the rain.
Steve
Steve
