Curious....I purchased a 63 Lark (one of those out of a barn deals) about three years ago, and put it in storage here at the house. It's number came up this summer and I began the process of making it run again. I discovered the water pump was leaking so I replaced. Upon replacement I was making a visual of the belt to see if it needed replacement. It is in okay shape...but upon my examination, I found the belt has "Studebaker" stamped on it. I have never seen one like this....is this a factory belt or did someone make aftermarket belts with Studebaker on it? The car is in solid shape, just cosmetic issues and shows less that 40K on the clock. I was just curious...anyone?
63 Lark Fan Belt
Quite possibly original if your car has that few miles on it. Certainly a factory best even if it is a replacement item.[^]
1963 Cruiser
1957 President two door
That's kinda where I am going. I have no way of authenticating the mileage, but once the dirt was removed and things cleaned, it fired right up, is quiet, doesn't smoke or LEAK. I just got home and checked the mileage...it shows 26730. Being THAT low makes me think that it is more likely 126730. In any event, I am going to spend some time with it and may just make it my daily ride this spring. Thanks for the information.
paul
1963 Cruiser
You know, Paul, in 1974 my Mother finally sold my Father's ranch. Included in the deal was a '62 wagon with less than five thousand miles on the clock. I didn't pay attention to that kind of thing back then, but I remember Mum remarking whilst we were leaving San Fransisco that the car had only five hundred miles on it. It spent the next six years in a barn before she let me drive it to school for a year. Four years later it went with the Ranch. I don't know what happened to it, but my point here isn't necessarily Grandmum's car. The fact of the matter is that Studebakers had a reputation in my childhood as an older person's car.[:I] Still do, as a matter of fact. It's entirely possible, inotherwords, that your car only had 26k on it. I would think that's possible as you mentioned that it doesn't leak or smoke and started so easily. Also, that belt is a dead give-away of low mileage. These cars don't seem to object as much as the big three's offerings to a hiatus in operation. Studebakers seem to appreciate a snooze once a decade or so. Kinda like the Rip Van Winkle of cars.
Home of the famous Mr. Ed!
Ron Smith
Where the heck is Lewiston, CA?Home of the famous Mr. Ed!
Ron Smith
quote:Originally posted by paynestude
That's kinda where I am going. I have no way of authenticating the mileage,/Cut/
Try these:
Door or door post lube stickers?
Radiator and Heater hose spring type clamps?
Older original formed Radiator hoses?
Three grooved, blue striped metallic Black heater hose?
Maroon Spark Plug Wires?
Champion spark Plugs?
Firestone or U.S. Royal bias ply Nylon 6.40/6.50X15 spare tire?
Black rubber covered, not plastic Prestolite Battery Cables?
Studebaker Battery? Lol, probably NOT in 2009! [)]
StudeRichStudeRich
Now I can't wait to get home and check some of this stuff out! I know when I replaced the plugs, they were Champion and the wires were a reddish brown (and dirty!). I have the spare tire in my garage and it is a bias ply, but unsure of the manufacturer. The battery had been replaced along with the cables. I don't remember about the hoses, and I believe there are service stickers on the drivers door jam. Maybe I will try to scare up a picture or two. I have started fixing the body on the car...looking for accident damage, etc. I have found an issue with the passenger side doors but other than that, it is solid. Currently I have all of the trim off the car and the rear bumper assembly. My goal is to paint it this spring and drive it this summer to work out any issues. Thanks for making me think about things that had not crossed my mind!
Try these:
You know, if the paint is not too awful, you might consider just putting a shine on it and leaving it. If you really do have a low-mileage survivor, it could be a real contender in the Unrestored/Original classes. As they say, it's only original once!
Clark in San Diego
'63 F2/Lark Standard
It is....it has had a repaint....Weatherbeater I believe. At least they tried to match the original green.
Clark in San Diego
