Ok I don't get it. I had a distributor rebuilt an a pertronix insalled in the dist.I put in the car a 259 6volt 55. Black wire to -side coil +side to ground no spark thenblack wire to -side coil black/white wire to + side coil new wire from + side coil to ground no spark. I dont get it am I just not seeing something. AAAARRRRGGGGG Help.
pertronix in a 6 volt
Make sure you have a GOOD ground. I had a few issues with mine at first also.
Owner of a 1950 4 door Commander
I'll Tattoo you anytime!
you can find me at
Lucky Linda's Body Art 952-445-3281
18 years in the tattooing bizI have a 1950 4 door Commander a 51 land cruiser And a 52 Champion
And you can find me at....
New Shop Name Same tattoo shop
Crazy Lady Ink
Shakopee Mn.
952-445-3281
27 years in the tattooing biz
55coupe,
I have been thinking about doing this on my little 232 V8. I have just started to research it a little more. Did you use the Igniter I and the 45,000 volt Flamethrower Coil? What were the product numbers you bought?
Thanks,
Jim
"Ahh, a bear in his natural habitat...a Studebaker!"
51 Land Cruiser (Elsie)
Jim Mann
Victoria, B.C.
Canada
\"Ahh, a bear in his natural habitat...a Studebaker!\"
Jim Mann
Victoria, B.C.
Canada
Studemann glade to share this with you. Ignitor part #1183p6, flame thrower 0.6 ohm coil 45000 volt 12volt universal coil. I was told the coil does not care if its used by 6 or 12 volts part #45011.I haven't done any driving yet,looking foward to a drive on Sunday.
The Pertronics units sure work I was just about to give up on my 65 as it would run one day and sputter the next. I had to drop HEI in my dads bowtie truck cuz the points system simply could not generate a hot enough spark to start it on this crap that is called gasoline now. I I did to the truck is replace the high compression heads that he had cracked for some rebuild non cracked ones and the treuck would not fire.
I did not have that option with a 194 because 250 heis are hard to find.
The pertronics did the trick and I kept thed stock ignition coil even.
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
61 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MCIf you car is ugly then it better be fast.....
65 2dr sedan
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
