View Full Version : HELP!
fire4effect
11-10-2009, 06:05 PM
Hi All,
I need 4.1 ratio ring and pinion for spicer 23 rear axle. Please let me know. Thanks!
Guido
11-10-2009, 06:33 PM
A little more information may help your cause.... What are you working on? Where are you located? Do you want used or NOS? Would you consider a complete axle?
http://thumb14.webshots.net/t/63/663/9/36/86/2567936860097493054TXiheL_th.jpgGuido Salvage - "Where rust is beautiful" and real Studebaker horsepower lives
fire4effect
11-10-2009, 06:44 PM
I'm working on a friend's champion car. Currently have 4.56 gears but want to go taller. I'm in NJ. We only need the gears. Do you have them?
fire4effect
11-10-2009, 06:47 PM
NOS or used will work. Prices?
Guido
I have a rear axle out of a '52 Commander but I think it is a 4.55 as well as a couple of 2R5 truck axles (don't know the ratio). If the car is a pre 1951 it will have a 4 bolt pattern and the Commander axle (5 bolt) will not match.
fire4effect
11-10-2009, 06:51 PM
I'm afraid that will not work. My friend specifically wants the 4.1 ratio.
dean pearson
11-10-2009, 06:59 PM
Stupid question I'm sure but I have a 52 rear end I cut down for mock up use. I was told it was a dana 44, is that the same thing?
If so let me know.
Dean.
fire4effect
11-10-2009, 07:04 PM
Dana 44 has different gears and carrier and larger housing compared with Spicer 23.
52-fan
11-10-2009, 08:31 PM
I believe the 4:10 gear set was usually found in Champions with automatics. Probably harder to find, but there should be some out there.
http://i152.photobucket.com/albums/s186/52-fan/StudebakersofArkansas2-1.jpg"In the heart of Arkansas."
fire4effect
11-11-2009, 04:56 AM
Thanks for the info guys
gordr
11-11-2009, 09:09 AM
I had a '54 Champion with overdrive that had the 4.10 gear set. This shouldn't be too hard to find.
Actually, I have a Champion parts car here that I've never checked the rear end on, because it's holding up the car. I'll see if it has a ratio tag on the axle.
fire4effect
11-11-2009, 05:20 PM
Gord, please check it whenever you get the chance and let me know asap. Dan
