View Full Version : Another "SPECIAL" question.
63t-cab
11-04-2009, 05:42 PM
I'd like to know about n.o.s. gaskit sets.are they good to use,or are only certain peices useable due to age? this is for V8 and 6. thank you.
Joseph R. Zeiger
Studeman
11-04-2009, 06:11 PM
Most of the cork gaskets will be unuseable... the rest are fine..
Ray
http://www.raylinrestoration.com/TEMP/azavatar.gif
63t-cab
11-04-2009, 06:21 PM
Thanks Ray,so even rear main seals and such are ok to use being that old?
Joseph R. Zeiger
Studeman
11-04-2009, 06:27 PM
I have several NOS rear mains (in "Studebaker" plastic bags) here that I have used over the years with no ill effects.. and they appear and feel like new ones.
I would inspect them carefully though for any signs of dryness or cracking.
The paper gasket for the valley cover is likely shrunk- a couple hours in some warm SOAPY water usually helps. Put it on, and let it dry again before gluing in place.
Usually no problems with the water manifold, or timing cover gaskets.
I haven't had any Intake or Exhaust manifold gaskets shrink either :D
Ray
63t-cab
11-04-2009, 06:35 PM
Thanks Ray,big help!this project is gonna be cheaper and cheaper.oh and the metal gaskits,that's a good one!
Joseph R. Zeiger
jclary
11-04-2009, 06:38 PM
I think that there are some environmental considerations regarding the gaskets. For instance, if the gaskets have been stored inside an air conditioned home or building in unopened packaging they might be OK. However, in areas where they are stored in extreme variations of temperature, like the attic of an unheated building where the temps become very hot in the summer and cold in winter, a lot of degradation could occur. In parts of the country where frequent electrical storms "fix" excessive ozone in the atmosphere, rubber components become prematurely brittle. I have had some OEM seals that were nice and flexible to the touch and have a packet stored next to them come out of the pack in pieces. Before I use any of the OEM gaskets I have...I always attempt to buy new ones first from a local parts store.
http://i518.photobucket.com/albums/u346/jconln/HPIM0372-2.jpg
PlainBrownR2
11-04-2009, 08:25 PM
The oil pan filler block pieces, that go on the front and rear of the engine. These are the nice thick cork gaskets that need to be bent if they haven't been bent already. If a gasket set containing these has been stored in a warm dry region, such as a warm attic, these will have a tendency to split and disintegrate if they are put to use. Over the years they can lose their pliability and become stiff and brittle. When they are inserted into the groove, they could possibly split, rendering the gasket unusable. I would recommend the Fel-Pro sets with some newer, more pliable filler blocks than leaving it completely up to chance by using the NOS sets.
[IMG=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/55%20Studebaker%20Commander%20Streetrod%20Project/P1010531-1.jpg[/IMG=left]
[IMG=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/55%20Studebaker%20Commander%20Streetrod%20Project/P1010550-1.jpg[/IMG=left]
[IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/Ex%20Studebaker%20Plant%20Locomotive/P1000578-1.jpg[/IMG=right]
[IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201964%20Studebaker%20Commander%20R2/P1010168.jpg[/IMG=right]
avantilover
11-05-2009, 12:52 AM
Try this link, it's an American company: http://www.bestgasket.com/
John Clements
Avantilover, your South Australian Studebaker lover!!!
Lockleys South Australia
