After a long wait, my starter was returned from the rebuilder with the usual battery connection but only a connection for the ign wire (S). No connection for the resistor (R) wire. He said that was the only solenoid available and was not sure what to do with the resistor wire but try connecting it to the strap between the solenoid and the starter. Will this work? help (again).
more 56olden hawk help
you mean the ballast bypass wire? yes, you can just connect it directly to the strap. If there were that terminal, it'd be directly connected to that same connection (internally to the solenoid) anyway.
Connecting that wire to strap between starter and solenoid is connecting your ignition to a ground which may have unintended results. A better
option would be a separate relay operated by the solenoid circuit. The correct solenoid is or was available from NAPA.
if you do find an exact replacement solenoid please post, I do not have a good number for one.
thanks
