Help I.D. a rear end tag 45B
  • Help I.D. a rear end tag 45B
    I have a rear end under a 61 Lark. I believe it to be a later model rear. It has finned drums. It is a Twin Traction with one of the tags noting: 3.31. That, I know is the ratio. The other tag has in large letters:45B. Can anyone help me with this? Is this the original rear for this car or is this from a later model? The axles are tapered. The backing plates use the later style wheel cylinders. The type with the staggered bolt holes. These are the same one I just replaced on a 63 disc brake car. Perhaps this rear end has later backing plates???
    sals54
    sals54
    The 45B refers to the disc&plate configurations of the TT pack. That's all. Everything else should be standard 44 stuff.
    1963 Cruiser
    1957 President two door
      Thanks for the quick reply. Now... does this rear end belong under a 61? The brakes are almost certainly later style.
      sals54
      sals54
        The `45' refers to Twin Traction and the `B' refers to the type of clutch pack used at this time. A `45C' replaced the `45B' in 1963. The `45B' can be either a #27 or #44 rearend. The Studebaker part numbers are the same for a #27 from 1960 to 1962 and are the same for a #44 from 1959 to 1962. This is according to the chassis parts catalog (if I understood it correctly). Somebody please correct me if I am wrong.
        Brent's rootbeer racer.
        In the middle of MinneSTUDEa.
          Sal - yes. Correct for a 61.
          1963 Cruiser
