View Full Version : Need a new distributor... got one now, thanks!
showbizkid
09-01-2009, 01:57 PM
My mechanical genius friend Kirk came over today and fixed my fuel leak (finally). I don't know quite what he did, but my hard line is now dry as a bone [^]
So we tried to set timing and found it bouncing all over the place. Heavy miss at 2k rpm showed the vacuum advance didn't work; lifted off the cap and found the rotor could be turned by hand about 20 degrees in each direction! Pulled the distributor and opened it up to find metal shavings, an advance weight lying in the bottom, egged-out attaching holes and other rotten-ness.
Kirk says the thing is shot, and I believe him. So, does anyone have a good replacement? I'd maybe like to put in a Delco if I can find it. Or, if you have a suggestion as to which vendor to talk to for a good rebuilt unit... that's welcome too.
(On the good side, we got the carb dialed in and the transmission in gear for the first time since the rebuild!)
Thanks in advance for your help... as always. You guys have saved me so many times :)
Clark in San Diego
'63 F2/Lark Standard
www.studebakersandiego.com
41 Frank
09-01-2009, 02:42 PM
Dave Thibeault sells rebuilt distributors, outright or exchange I believe. He also markets the new Mallory although it is a little pricy. Might want to give him a call to see what he can do for you.978 897-3158
dean pearson
09-01-2009, 03:57 PM
I have an old one in my garage but have no idea what type it is.
If you will email me direct I can send you a pic but am unable to post it here.
dpearson@scwcompanies.com
If it is the one you need I am in murrieta Ca. and I believe you are in San Deigo so I could meet you half way.
No Charge.
Dean.
Warren Webb
09-01-2009, 04:00 PM
Clark, I have a Delco window distributor your welcome to have. Next time your up this way off the 215 call me.
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan
showbizkid
09-01-2009, 05:52 PM
Thank you Dean - sorry it didn't work out.
Warren - thank you! Email sent.
Clark in San Diego
Warren Webb
09-01-2009, 05:54 PM
Clark, your car was made with the Prestolite distributor which, hearing what is wrong with yours, isnt unusual. Although the Delco isnt correct for the year of your car, it is a more dependable unit & is easy to convert to electronic ignition later if you desire. Not saying the Prestolite cant be converted, but with the Delco, replacement parts are easy to obtain.
60 Lark convertible
61 Champ
63 G.T. R-2,4 speed
63 Avanti (2)
showbizkid
09-03-2009, 08:47 PM
Warren, thanks again. Great meeting you and talking! I've already begun getting the parts together for the distributor. (And if you come home one day and the Hawk is missing, you'll know where to look!)
Dean, I look forward to meeting you soon as well!
Clark in San Diego
bige
09-03-2009, 09:00 PM
A problem I ran into when I had the Delco on the Avanti was with the rotor. Don't know what brand it was but the reinforcing ribs on the underside would contact the advance weights and interfere just enough to give an intermittent timing problem. They wouldn't return all the way all the time so I would constantly have to adjust the initial timing. Replacement parts today are just not the same quality as original Delco. Just an FWI.
http://i146.photobucket.com/albums/r241/AvantiR2/track.jpg
On its way to a 15.097 Island Dragway Great Meadows NJ Spring 2006.
09-03-2009, 09:16 PM
Clark,
I was moving my compressor to a new location today and found an early Delco stashed behind some boxes. E-mail me if interested.
http://imagehost.vendio.com/a/30906179/aview/58_Avatar.jpg
1963 Cruiser
1957 President two door
Warren Webb
09-04-2009, 04:04 PM
Clark, it was a pleasure to meet you the other day. Glad to be of some help. Perhaps we can all get together with Dean & possibly Ross & others here in the west end of Riverside & San Diego counties for a chat with some donuts & coffee.
60 Lark convertible
61 Champ
63 G.T. R-2,4 speed
63 Avanti (2)
showbizkid
09-04-2009, 04:33 PM
That'd be fun!
Clark in San Diego
