Last Friday we final got the time at the shop to put the new rear brakes on my 63 lark wagon. While up in the air I figure I would run the car through the gears to make sure the trans was working right. well that was ok but seems that the passager side axle is bent. need to find a axle now. What I want to know is
1 are both axles the same size or is one shorter then the other?
2 are the 6 cyl axles different the the V8?
3 how many years did Studebaker run the rearends that were in the 63 models.Up here there is little in the way of Studebakers around and so far all I can find is a rearend from a 51 Stude pickup.I`m wondering if these axle might fit.
fitzee
fitzee
