View Full Version : 53 Coupe secondary hood latch
petercalaguiro
07-26-2009, 07:52 PM
I am looking for a good secondary hood latch for my 53 coupe. If any one has a spare or can tell me where to get one I would appreciate it.
Thanks,
Peter
02G0200
Nelsen Motorsports
07-26-2009, 10:34 PM
Can you show me a picture of what you are talking about? I may have an extra.
http://i558.photobucket.com/albums/ss29/NelsenRacing/n1558086144_30050401_419-1.jpg
Alex Nelsen
1954 Champion Coupe
Lizella, GA
barnlark
07-26-2009, 10:56 PM
SASCO? They had a ton of shiny ones. Not sure of that year.
candbstudebakers
07-26-2009, 11:35 PM
A piece of 3/8' chain about 4' long with a pair of holes in the hood and lock on the bottom, don't loose the key.
Castro Valley, CA
http://i691.photobucket.com/albums/vv271/canbstudebakers/IM000994-1-1.jpg
sals54
07-27-2009, 12:00 AM
I use a bolt (with the head removed) which is screwed into the hood support structure at the front, which penetrates the front of the grill near the hood release. The bolt is drilled to accept a clevis pin. The only time in 30 years I forgot to put the pin in, the hood popped open at speed. You should see what happens to a 53 hood when it "pops" open at 60 mph. It ain't pretty, I can tell you that. I had to use a piece of concrete that I found on the side of the road to hit the hood from the bottom, cuz it had bent in half. Can you imagine how difficult it is to be standing on the front bumper, holding a jagged 5 pound piece of concrete, swinging it in an upward motion, trying to bang the crease out of a once perfect 53 hood, all the while, cussing at the moon and stars for being so stupid as to have forgotten to check the secondary hood safety ? ? ? ? ? ? ? It took me about 20 minutes to calm down enough just to take a call from my wife who was wondering where the heck I was. I always check the safety pin...... NOW ! ! ! ! ! The only saving grace about the story was that I had a spare hood at home. I changed it out the next morning. This is the time where its good to have a hotrod in black primer. It looked good as new in about a half an hour. Now I only have one spare hood left.
sals54
http://i296.photobucket.com/albums/mm197/sals54/NewSignature.jpg
petercalaguiro
07-27-2009, 07:39 AM
Thanks to all, "chain man" included. I will try Sasco first.
Peter
02G0200
Lark Parker
07-27-2009, 08:03 AM
I removed the forehead grab hook -- it doesn't work well anyway.
Installed a GT Hawk hood latch with a cable pull. Right behind the existing "spring mounting" on the tube in the hood, I added a hook for the GT's built-in safety latch to grab.
No additional holes required. Has worked well for 19 years.
Can take a picture if interested.
This should be allowable for a show car (my opinion) as it is for safety.
LP
blackhawk61
07-27-2009, 08:17 AM
The best solution !
http://i245.photobucket.com/albums/gg72/blackhawk61/Hoodlatchpin1.jpg
1961 Hawk 4BC,4-SPEED,TT
http://i133.photobucket.com/albums/q55/chevpartsman/61HawkChevypartsmanreduce.jpg
Ken Byrd
Lewisville,NC
candbstudebakers
07-27-2009, 09:49 AM
The chain way is used on a lot of chevy and fords as their hoods are easy to come by, I was just kidding on the use of a 53-54 c/k hood they are just to hard to find a good one now days , good luck and keep the hood down...Bob
Castro Valley, CA
petercalaguiro
07-27-2009, 10:32 AM
I like this idea. Thanks,
Peter
quote:Originally posted by blackhawk61
The best solution !
Ken Byrd
Lewisville,NC
02G0200
blackhawk61
07-27-2009, 10:58 AM
Works VERY well Peter.
http://i245.photobucket.com/albums/gg72/blackhawk61/Hoodlatchpin2.jpg
Tractor Supply 3/16" Lynch pins
Ken Byrd
Lewisville,NC
R3 challenger
07-27-2009, 11:08 AM
Cousin Bob Palma can tell this better than I since he was there, but back in the 1960s, he was riding with Uncle Jerry in Jerry's supercharged 1963 GT Hawk. They were on a straight, clear road in central Indiana at a speed somewhere North of 110 mph when the hood came up. (Jerry was what you might call an enthusiastic driver). Fortunately, the window was open, so Jerry brought the beast to a halt while looking out the driver's side window. Bob escaped with a bump on the head. The roof of the Hawk was never quite the same, but it was repaired.
From that day on, neither Bob nor I will move a Hawk without some kind of hold-down device. My '58 Golden Hawk has an 8" chain that was installed by former owner Asa Hall. The link at the top end is welded to the support where the large spring is mounted. A separate link is welded to the lower front of the hood latch support and a padlock is used to hold things together. When the hood is open, the chain can be placed on top of the spring support and is barely noticeable. Thanks, Asa.
BTW, I sure like the linchpin idea. Thanks.
George
george krem
barnlark
07-27-2009, 11:18 AM
Well, that explains everything. You sure he actually escaped? ;):D
petercalaguiro
07-27-2009, 06:03 PM
I run an air dam below the bumper when I am racing, but even without it, you would have to be a contorionist to get at that ring. Perhaps it is easier with a Hawk hood?
Peter
The best solution !
Ken Byrd
Lewisville,NC
02G0200
02G0200http://i729.photobucket.com/albums/ww294/petercalaguiro/DSC_0062_3_1.jpg
R3 challenger
07-27-2009, 10:24 PM
[quote]Originally posted by barnlark
Well, we're both alive and equally sane. Hmmmmmmmm....
george krem
barnlark
07-27-2009, 11:21 PM
:D:D:D More sane than most, I'd say.
