how about oil leaks on the 6's.what is there problem area? just gathering info. for future projects.
6-cylinders oil leaks
The only problem that I had with a Champion six leaking oil was around the side covers when I installed the gasket wrong. The stock hub seal in the timing cover also weeps when parked, but is not a problem on the road. A modern neoprene seal would probably cure the timing cover leak.
Bill Cathcart's site has pictures of some dressed up sixes if you haven seen them.
1952 Champion Starlight, 1962 Daytona, both w/overdrive.Searcy,Arkansas
"I may be lazy, but I'm not shiftless.""In the heart of Arkansas."
