I know there is a way to adjust your vacuum advance other than driving up and down the street untill you get it right. The Factory had a way and I'm sure they didn't drive up and down the street.
When you time your engine you disconnect the vacuum and time it to IGN on the pully. When you reconnect the vacuum should you see about 15 degrees on top of the the fixed initial timing setting? Is that the correct way? Maybe some of you don't go that far back when they make that Studebaker, But there must be a better way than driving up and down the street. I live in W.Va. and trying to find a street that is level is one thing and driving up and down a hill with a master cyl.that is single is not the way I want to go.
1950 Champion business coupe
