In my haste to bolt the head onto the block I forgot to attach the oil filter bracket. The head has been torqued to spec. If I remove the two bolts and install the bracket will this damage the head gasket? If not, when tightening the bolts should I do all the bolts in the proper sequence or just the two that I screwed up? Thanks.
head bolt error
Like buddymander said- no problem. However, I re-torque heads after driving a car for a while anyhow.
Paul Johnson, Wild and Wonderful West Virginia. '64 Daytona Wagonaire, '64 Daytona convertible, '53 Commander Starliner, Museum R-4 engine, '62 Gravely Model L, '72 Gravely Model 430
