Getting some work done in the last few days, yesterday I got the broken screws out of the lower door hinge mount. Earlier that day, I picked up a bag of cone head screws and conical lock washers to replace the stock screws in this truck projext and my hardtop.
I hung the right door so it closes with a good slam. I will need to bring down the floor jack to hold it while I tweek it some so it will close with a push.
Things to do in the next few days, budget and time permitting:
Need to go to a local metal supplier for some square tube to run from the hinge post to lock post and points back and get some plate to make some new body mount brackets.
Need to get a degreaser to remove what I think is tranny lube off some of the floor before I try to weld... how tranny lube got there????
Need to figure out where I can get used conveyer belt for body mounts locally.
Need to drill out broken screws in the left door.
Need to figure out floor welding joint style, lap joints, butt joints, plug welding, not worried about looks... once I build it, I'll beat it and fix it
Anybody ever use a piece of angle iron, some vise-grips and a hammer as a metal brake?
Going to see what I can do on the truck in the next day or two, I also need to start on a fence around the yard to keep in an active three year old and the future puppy she desires.
Jeff T.
"I'm getting nowhere as fast as I can"
The Replacements.
Jeff T.
The Replacements.
