Three days ago, I demanded that I be shown the compression tests done on my newly rebuilt straight 6 engine.
I discovered that the 'supposed correct and normal method' was to remove all spark plugs, and have someone crank the starter --each time a pressure gauge had been screwed into one of the cylinders.
The several very troubling things were that if the cranking went 4 times or 5 times the pressure continued to build so the reading was a "hit and miss" ordeal of guessing what the reader said. Is it possible to be more accurate than that?
I firmly believe that the guy who decided what the gauge read could have controlled what he says he read as much as he pleased.
Is there a more accurate and absolutely standard way of doing this??
Jim
James Caspi
1950 Champion Regal Deluxe-2 dr.
New York, NY.
Jim
James Caspi
New York, NY.
