My three year old pooped out early last night so I finally got a chance to run my V8 T86 overdive through the spin test, turn input shaft.. shift transmission, see if output shaft turns... it does The transmission is sitting on my workbench in the basement and I still have to pop the top cover off to look inside. With any luck all I need is to flush out the old lube and fill it up.
Before I open it up to inspect and clean the T86, what should I inspect short of dismantling the transmission (if it ain't broke rule). I have has good luck over the years finding good transmissions from donor cars and I hope my luck holds but this is my first overdrive.
thanks for any advice
Jeff T.
"I'm getting nowhere as fast as I can"
The Replacements.
Jeff T.
The Replacements.
