Does anybody know what would fit my 53 commander. I got the car without a gas tank'[?]
53 gas tank
A lark wagon tank can be made to fit too. I used a NOS one a few years ago in my '53. The tank is a little shorter front to rear than a C/K tank so the hangers need to be adjusted: Left front one drill a hole 1" over on the tank's mounting tab. The right hanger bracket can be rotated a little to line up. The only other mod was to bend/tweak the filler neck a little so it was not quite so vertical (hits the trunk floor otherwise).
Don't recall what year(s) of wagon tank it was anymore or if all lark wagons had the same tank or not?
Jeff in ND
'53 Champion Hardtop
Jeff in ND
I used a repop tank from a 49-52 Chevy that I got from Tanksinc.com. Had to do some mods to the filler neck and figure out a frame work to mount it using straps like the Chevy used. I needed a tank that was slightly deeper in order to run an in tank electric pump for my fuel injection. It was quite a bit of work, but once done was trouble free. You can see details in my project journal linked below. Entries 14 & 15 on page 11-12
Pat Dilling
Olivehurst, CA
LS1 Engine Swap Journal: http://www.hotrodders.com/forum/jour...ournalid=33611Pat Dilling
Olivehurst, CA
That's interesting, as I have sent back to Mark II industries my old Lincoln gas tank as a core return from NJ to California UPS.I believe it can only ship ground like any flammable product.
I thoroughly flushed it out first with plenty of water and let dry in the sun.
Jack
1955 SPEEDSTER LEMON/LIME
1955 SPEEDSTER RED & WHITE
1964 R2 GT HAWK (SID)
