Okay...I took my Lark out for the first time today after rebuilding her, in 10 degree (F) weather. (it was sunny and dry, although there is still powdered salt on the roads[xx(]...but I couldn't wait to try her out!!)
I have rebuilt the prestolite distrubutor, (including weights, cam, rotor, cap, points, condenser) I have also advanced the timing about 5 degrees. (it was running at about 5 degrees retarded before I did any work to her) I have also replaced the wires and plugs (first time in 8 years,[B)] if the previous owner tells me correct)
She undoubtably runs much better! However, once on my 40 minute test drive, she wanted to do her old thing...it was not as bad, she would not stall, just stutter a bit. And she only did it once, as opposed to almost all the time. I wonder if it isn't a carbueretor issue after all?? I did a lot of speeding up, stop-and-go driving, giving her the third degree. (for those of you wondering what the original symptoms were, click here:
Overall, I must say, she does drive like a different car! I cannot tell you how her performance has improved!! (I wonder how much of that is due to the super cold air)
Anyhow, I was not happy that she wanted to idle poorly that one time (yes, she was fully warmed up) I am confused as to why it has improved, but not gone away. Any help would be appreciated.
Also, as far as timing goes...how far should I advance the stock 259 for peak performance? I am not going to drag race her or anything, but call me crazy, I want my car preforming at its peak, what is the point of driving a V8 if it isn't running at its full potential?
Thanks again guys!
1963 Lark, waiting for spring...
Thanks again guys!
