I have a 1959 Studebaker pickup with a good running 289. I also have the matching number 289 that came out of it. It needs alot of work. Should I rebuild it and install it or just leave it as is,
matching numbers, does it matter
There were/are probably 20 individual Studebakers from each year that are/were significant enough (rarity/option package/noteriety/famous owner) to warrant matching serial numbers.
This is a 'drivers club', so most here will tell you to fix your brakes, put good tires on it, and drive it as much as you can...
(Especially next July 4th![])
Hope the info helps..
quote:Originally posted by TMAN0950
I have a 1959 Studebaker pickup with a good running 289. I also have the matching number 289 that came out of it. It needs alot of work. Should I rebuild it and install it or just leave it as is,HTIH (Hope The Info Helps)
I have a similar thread "Matching Numbers" on 10 November and received excellent replies. I too have a spare engine. The comment that SDC is a drivers club and not a collector's club explains why this site is so valuable. Although we like to get cars as "correct" as is practicable, the joy I receive when I drive it and someone wants to talks is immeasurable. However, it would be nice if instead of "My father or grandfather used to drive one" it would be nice if someone said, "my kid has always wanted a Studebaker" I was one of those kids so many years ago
Funny you should ask since the boys at Omaha 2006 checked the production order on my car during judging. And then there's the '45' tag. I think someone from Arizona dreamed that one up.
Claude Chmielewski
Studeski
Fillmore, Wisconsin
47 M-16 Truck
62 GT Hawk
63 Lark
64 Commander Wagonaire
50 Champion Regal (parts car)
[img=left]http://www.studeski.com/62hawk/62hawka/dakota01_250.jpg[/img=left]
1936 Dictator
1950 Champion Regal 4 dr parts car
1953 Commander Regal HT
1953 2R5 Pickup
1947 M16 Truck
1960 Lark VIII Convertible
1960 Champ 5E7 step side short box
1962 Champ 7E5 no box
1962 GT Hawk
1963 Lark VI 4 dr
1963 GT Hawk R2
1964 Daytona Convertible
1964 Commander Wagonaire
“America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.” ~ Abraham Lincoln
Here's that link:
http://forum.studebakerdriversclub.c...TOPIC_ID=23870
quote:Originally posted by mdelapp
I have a similar thread "Matching Numbers" on 10 November and received excellent replies. <snip>HTIH (Hope The Info Helps)
quote:Originally posted by hotwheels63r2
Judges will do that when it comes to the lower production cars, especially if there are 2 present at the show. Did they get you because it was missing? explain more...
Claude Chmielewski
Studeski
Fillmore, Wisconsin
47 M-16 Truck
62 GT Hawk
63 Lark
1936 Dictator
1953 2R5 Pickup
1947 M16 Truck
1962 GT Hawk
1963 Lark VI 4 dr
1963 GT Hawk R2
IIRC, the tag numbers refer to the number of teeth on the pinion, and the number of teeth on the ring gear.
Divide the two numbers and you have the rear end ratio...
quote:Originally posted by studeski
Yes I have a TT axle and it was missing. I believe he was a new judge and thought that tag was really important. All it designates is the ramp angle in the TT case. It can be 45 or 30 - meaning degrees. Maybe the guy who made such a big deal out of nothing can fess up. I had never before seen judges look at production orders at a Studebaker show.HTIH (Hope The Info Helps)
I believe he was a new judge...
If there are only a few cars in a class, the judges will generally spend a lot of time on each car which can result in more "gigs" than a class with a lot of cars where even 10 minutes per car will result in a 10 hour day for the judges in that team.
Meet to meet and class to class, judging and scores can and will be VERY different. I personally can't see any way around this.
Bellingham, WA
[IMG][/IMG]
Bellingham, WA
Jeff, you are referring to the Tag at 7:00 (left side) and Claude is referring to the one on the RIGHT side at 4:00 on TT Axles that indicate the ramp angle.
Apparently they saw the Prod. Order had a TT and or the TT Emblem, and expected to see a TT, or 45,B,or C etc. tag on the axle! [:0]
Goes to show ya, Prod. Orders are neat, but do not gain any points, but can BITE you! Be safe, remove the Prod. Order for judging!
StudeRich at Studebakers Northwest -Ferndale,WAStudeRich
quote:Originally posted by StudeMichael
Almost as good as the R4 set up and the set of Halibrands you sold me back in 2004 Allan!!
1957 Packard Clipper
1958 Golden Hawk
1963 Daytona Convertible
1963 R2 Daytona
1963 R2 GT Hawk
1963 R1 Wagonaire
1963 R4 Avanti
1964 Champ
1966 Cruiser
quote:
If you have a Jet Thrust powered Lark or Hawk it is nice to have the JT or JTS number on the block in my opinion.
[img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201950%202r5%20Studebaker%20Pickup%20with%20turbocharger/P1000137-1.jpg[/img=left][img=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201950%202r5%20Studebaker%20Pickup%20with%20turbocharger/P1000145-1.jpg[/img=left][IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/Ex%20Studebaker%20Plant%20Locomotive/P1000578-1.jpg[/IMG=right]
[IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201964%20Studebaker%20Commander%20R2/P1010168.jpg[/IMG=right]
