View Full Version : Hemi block ?
JDP
11-10-2008, 02:13 PM
Anyone need a Hemi block, and crank from a Dodge D 500 ? I can get it from the guy I bought the hemi Hardtop from if it's worth hauling home.
JDP/Maryland
"I'm a great believer in luck and I find the harder I work, the more I have of it."
Thomas Jefferson
11-10-2008, 04:11 PM
The guys over on the H.A.M.B. would snatch it up in a heartbeat. If usable, I'd guess $250.
thnx, jack vines
JDP
11-10-2008, 04:55 PM
OK, I'll drag it home, thanks.
JDP/Maryland
Thomas Jefferson
buddymander
11-10-2008, 09:55 PM
Hey--If you can get it to Los Angeles; put my name on the list of interested persons.
JimmieD
11-10-2008, 10:10 PM
If it's a 392 ['57-'58] Hemi it's worth bunches!
11-10-2008, 10:43 PM
Hi, Jim,
Not
quote:a 392 ['57-'58] Hemi it's worth bunches!
it's a
quote:block, and crank from a Dodge D 500
thnx, jack vines
DEEPNHOCK
11-10-2008, 10:57 PM
Tom Covington has a complete Hemi on his engine stand (complete with 2bbl intake and carb).
It's for sale cheap ($600 or so)...
http://i77.photobucket.com/albums/j54/deepnhock/1937CEBearfootingArtwithLabelgif-1.jpghttp://i77.photobucket.com/albums/j54/deepnhock/SDClogo4forum.jpghttp://i77.photobucket.com/albums/j54/deepnhock/StudebakerTruckFarmerStickerA-1.jpghttp://www.racingstudebakers.com/avatar_01.jpg http://community.webshots.com/user/deepnhock
buddymander
11-10-2008, 11:30 PM
I could probably identify it with just the bore. And dodge did use chrysler hemis in their trucks. But the stamped number front of the valley cover will tell the story. What is the location of the $600 hemi?
laughinlark
11-11-2008, 12:11 AM
Never been a brand X guy but, I had a chance to run a FED with a SBC naturally aspirated on race fuel . I ran an 8.80 @ 151 at best. There was a guy with a 354 Hemi running 8.20's on alcohol.
Gordon
http://i157.photobucket.com/albums/t60/laughinlark/gordsjsmk-1.jpghttp://i157.photobucket.com/albums/t60/laughinlark/11-28-07130-1.jpghttp://i157.photobucket.com/albums/t60/laughinlark/all283.jpg
bridgegaurd
11-11-2008, 02:15 AM
quote:Originally posted by PackardV8
Hi, Jim,
Not
it's a
thnx, jack vines
Don Garlits didn't gain his early fame with a chyrsler hemi. Check his history he used the early dodge. It's definently worth hauling home.
53k
11-11-2008, 07:51 AM
I tried out a '56 D-500 back in late 50s. Pretty impressive- 0 - 100 in 19 seconds (by glancing at the second hand on my watch as I GRIPPED the wheel:)). That was a four door sedan with the two-speed Powerflite a/t. I think it had solid lifters unike the regular hemis that had hydraulics.
Paul Johnson, Wild and Wonderful West Virginia
Museum R-4 engine
1962 Gravely Model L (Studebaker-Packard serial plate)
1972 Gravely Model 430 (Studebaker name plate, Studebaker Onan engine)
buddymander
11-11-2008, 10:19 AM
I'm pretty sure there was a D-500 car and a D-500 truck as well. Dodge trucks continued to use hemis long after 1958.
bob40
11-11-2008, 03:57 PM
The trick is finding a D-501!!
1957 Dodge D501,only one hundred cars were built for NASCAR and drag racing use. Factory-installed 354 cubic inch Hemi engine, dual quad carburetors, oversize brakes and special racing suspension.
ST2DE5
11-11-2008, 06:59 PM
It's probably a 315 if it's a 58
http://i220.photobucket.com/albums/dd185/51stude/Untitled-2-1-1.jpg
JimmieD
11-11-2008, 08:54 PM
May be 331, 354 or 392. '58 was the only year of 392 but there can be confusion on VIN's so you might say '57-'58. I'd say most often a 318 Poly, 354 Hemi or rare 392 Hemi in a big truck in '58.
Most Chrysler products were only offered with wedge-head engines after '58 but I've heard of Hemi's being used for a year or two more, only in bigger trucks.
Sort of the same with Mopar 318 Polyspherical V8, discontinued at '66 model year but my own '67 came with a Poly from the factory, and they were used in commercial trucks up until '72! The 318 Poly has a scalloped edge at the bottom side of rocker covers, cover retained with only 2 bolts, and no hole in rocker cover for sparkplugs like a Hemi has.
bob40
11-11-2008, 10:18 PM
12 or 13 varieties of early Chrysler product Hemi engines
A primer link here.
http://www.crankshaftcoalition.com/wiki/Early_Hemi_engine_specifications
ST2DE5
11-11-2008, 11:25 PM
You can give me the numbers off the block and I can tell you what it is and what car it came out of.
JDP
11-11-2008, 11:37 PM
It's a 315 out of a D 500, but I don't have it here.
JDP/Maryland
Thomas Jefferson
Warren Webb
11-12-2008, 12:08 AM
I remember as a kid my dad coming home on a "test drive" from work with a brand new Dodge Coronet 2 dr hardtop with a D-500. I had a cowboy hat on & when he hit the gas, my hat flew off into the rear package shelf!! Some things you never forget!
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan
Warren Webb
11-12-2008, 12:09 AM
60 Lark convertible
61 Champ
63 G.T. R-2,4 speed
63 Avanti (2)
black56hawk
11-12-2008, 05:28 PM
Sorry, all his early hemis were Chryslers. Didn't use a Dodge hemi until he switched to 426 hemis
black56hawk
11-12-2008, 05:34 PM
JDP/Maryland
Thomas Jefferson
If it's a 315, it came out of a 56 D500. Block and crank are the same as the 315 Dodge poly.
57 D500 was a 325 hemi. In 56 and 57, only D500's had hemis; non-D500 Dodges were polys.
56 and 57 Dodge hemis were raised deck versions of the original Dodge hemi introduced in 1953 with only 241 cubes.
58 and later D500's used big block wedge engines.
