View Full Version : wheel removal... um.. yeah...
Busmark181
10-17-2008, 06:47 PM
so, I decided that since none of my tires are actually the same size, and 1 still has a tube... yep, a tube... I would remove the wheels tonight and get new "used" tires this weekend as well as all my other planned adventures....
well... jacked the car up, put it on stands, and the passenger side came off without a problem... 10-15 minutes worth of work and we got down to brake drums....
Have to admit... I did struggle with the driver side for a good 2 hours... none of the lugs would give... got a hammer... didn't help... finally thought that maybe if I tighten a lug, and then remove it, it might give... That's when I figured it out....
that's when after 2 split knuckles, I found that the drivers side is reverse threaded.... yep... 2 hours, 2 knuckles, apparently 2 brain cells....
um, is this common? or has my vehicle been frankenstiened? I feel like I just went through a Studebaker right of passage.... I feel like I might be a man now... either that or my car is just screwed up!!!!!
are the Studebaker Gods laughing at me?
what the heck? reverse lug nut threads? when was that a good idea?
oldguy
10-17-2008, 06:51 PM
Nope, drivers side is left hand thread, and not that uncommon, back in the day.
We busted 2 studs off before the light came on, which was stupid, since my 41 Pontiac was the same way.
San antonio TX. 53 Champion Coupe, to be brought back from the dead.
"Of course it will fit, I have a torch"
Busmark181
10-17-2008, 06:56 PM
san antonio as well... and glad I'm not the only one that didn't know!!!!! LOL Cheers!!!!
Busmark181
rockinhawk
10-17-2008, 07:03 PM
If you will look on the end of the lug bolt it should be marked either L or R. Some time the drums get switched from one side to the other. NT
Neil Thornton
Hazlehurst, GA
'57 Silver Hawk
'56 Sky Hawk
'51 2R16 dump truck
Many others.
http://i81.photobucket.com/albums/j209/mbstude/avatar2.jpg
Busmark181
10-17-2008, 07:06 PM
I did figure that our later... granted I couldn't "read" a lug end due to all the red paint I asked about earlier... but as the lugs came off... and the paint.... that became more and more apparent... LOL
Busmark181
wolfie
10-17-2008, 07:32 PM
Are mine backwards?The reversed threads are on the passenger side.Seems to make more sense as inertia would tend to tighten them rather than loosen them (maybe warped thinking)Steve
wolfie
rockinhawk
10-17-2008, 07:37 PM
As best I remember Left goes on Left side. I usually change all mine to right hand thread. NT
Neil Thornton
Hazlehurst, GA
'57 Silver Hawk
'56 Sky Hawk
'51 2R16 dump truck
Many others.
Flashback
10-17-2008, 08:26 PM
Left hand thread lugs are always on the left side
Tex E. Grier
http://i307.photobucket.com/albums/nn320/Flashback53/Studebaker255.jpg
Flashback
Tex E. Grier
rockne10
10-17-2008, 09:03 PM
Freightliner still makes their medium duty trucks that way.
Back in 1959 my Dad twisted a 4-way lug wrench in to a pretzel on the left side of his '51 Hudson. He was a strong dude.[:0] It was just a question of mind over matter. His mind was saying, "You're coming off!":(
Unfortunately, the matter was saying, "Oh no I'm not!"[:o)]
Brad Johnson
http://s57.photobucket.com/albums/g233/rockne10/Rockne/th_Rocknegauges.jpg'33 Rockne 10, '51 Commander Starlight, '53 Commander Starlight
rockne10
Brad Johnson
dictator27
10-17-2008, 09:25 PM
Chrysler was like that, too. Years ago, I watched a mechanic have a major senior moment. He took the wheels off a 61 Chrysler, so he obviously knew about the threads. Then he takes one of the front wheel hub caps, turns it over and puts the wheel nuts for both front wheels in it. Does the same for the rear wheels. Comes the time to put the wheels back on - using his impact wrench, of course - he puts the nut in the socket, bangs it up against the stud and lets fly, starting on the driver's side. Took him a while before he finally figured out why a lot of the nuts wouldn't go on! By that time there were a number of stripped studs and nuts that needed replacing.
Terry Godkin
BobGlasscock
10-18-2008, 09:12 PM
left hand threads and starter buttons under the clutch. That Studebaker company was one sneaky business. What next?
'50 Champion, 1 family owner
http://i251.photobucket.com/albums/gg316/studebakerbob/SDC%20avatar/Studebakerstuff019.jpghttp://i251.photobucket.com/albums/gg316/studebakerbob/SDC%20avatar/Studebakerstuff018.jpg
BobGlasscock
