A while back I asked a few questions regarding the possibility of AC for my 51 Champion. Thanks, BTW for all the good info I got.
Kent Fedor sent me a pulley/vibration dampener assembly for a Champion 6 w/AC (2nd pulley in front of the vibration dampener for the condenser belt). I haven't mounted it yet, but several questions arise when I mock it up.
First, as my engine is set up now, this pulley would interfere with the fan blade. There's no way this would fit without moving the fan forward about 1/2 - 3/4". Did engines with AC have a different water pump or longer "nose" on the fan pulley? Or was a spacer used? Also, this would mean moving the radiator forward a bit since the fan is already very close. All this is do-able, but I just wanted opinions before making any other decisions. I received some advice from some SDCers that mounted the condenser/alternator assembly on the drivers side, without the extra pulley on the vibration dampener, so that's an idea also.
Anyway, I have the stock compressor bracket and the stock pulley assembly, but without modifications, this won't work. As I said, I can make the modifications, but am I missing some crucial info about 6's with AC?
Las Vegas, NV - Stop by, coffee's on!
