View Full Version : Water manifold is on
showbizkid
09-01-2008, 11:14 PM
Another good Stude day :D Only had two hours to work on the Lark, but it was enough to get the water manifold on. I also got the alternator bolted in and hooked up.
Am I reading the shop manual right? Is the torque spec on the water manifold bolts really just 12 - 17 foot-pounds?
http://i132.photobucket.com/albums/q26/clarknovak/Engine%20Install/DSCN1398.jpg
Clark in San Diego
'63 F2/Lark Standard
www.studebakersandiego.com
bams50
09-02-2008, 05:07 AM
That sounds a little light, but if that's what the manual says...
I've never torqued one, personally- I usually just tighten by feel. I think the internal items and the head bolts' torque specs are critical, the rest are more of a guideline to give you an idea how far to tighten.
Parish, central NY 13131
09-02-2008, 05:15 PM
Yes that would be correct for a tiny little 5/16 in. bolt. I am sure 20 Ft. Lbs. would not hurt them, but with 8 of those babies, the Manifold is not going anywhere! [^]
Studebakers Northwest
Ferndale, WA
09-02-2008, 05:47 PM
Lookin' good, Clark.;)
1957 President two door
N8N
09-02-2008, 06:53 PM
20 ft-lb. will likely destroy the stock manifold clamps, they're the weak link not the bolts.
edit: oh, we're talking about the water manifold, not the intake. In that case a little more torque shouldn't hurt anything - so long as the bolts are real grade 5 - but probably not necessary, that whole mess is pretty precisely machined.
09-02-2008, 06:58 PM
But the Intake bolts get 30 Ft. Lbs. though, being 3/8" bolts!
Ferndale, WA
