The other night I was driving home from a little show & shine. Before I got home it got dark so I put the head lights on. Seamed like the right thing to do. I was traveling on a frontage road to avoid Hwy. 101 pot holes. So I turned on the high beams. All was fine until I got to an itersection. I turned on my left turn signal and got the left signal but the indicator on the dash showed I had the right signal on. When I went to the right it showed the left signal was on. OUT SIDE LIGHTS OKAY- INSIDE SHOWS OPPOSITE DIRECTION.
Turn high beams off and all is as it should be. With lights off all is good.[}][?]
Can't see where the high beam switch hooks up with the turn signals in the shop manual. It shows the flasher goes to the ignition switch but doesn't say what terminal.
Any thoughts that wont require me to find a wizzard.[)]
John Ratliff
John Ratliff
